TEMA: AR 925E zvučnici
AR 925E zvučnici 24 Lis 2014 00:04 #8927
:thumbup: Sada malo da predstavimo i zvučnike! Mogu vam samo reći da to svira samo tako!
Prilozi:
Posljednja izmjena: 24 Lis 2014 00:15 od htomasov.
AR 925E zvučnici 24 Lis 2014 14:39 #8932
:obrva:
System 3 ways, 3 speaker acoustic suspension system, and a floor type
Use unit For low-pass: 25cm corn type
For inside regions: 3.8cm dome shape
For high regions: 1.9cm dome shape
Frequency response 32Hz - 30kHz
Low-pass play frequency 44Hz -3dB
System Q 0.7
Output sound pressure level 90dB/W/m
Impedance 4ohms
The continuation maximum input 125W
The maximum input 200W
Crossover frequency 700Hz, 7.5kHz
Level control Inside region: Three-step switching
High region: Three-step switching
Content volume 46.8L
Dimensions Width 356x height 797x depth of 290mm
Weight 21kg
Posljednja izmjena: 24 Lis 2014 14:40 od htomasov.
Stranica se generirala za: 0.155 s
