TEMA: Hermann Thorens
Odg: Hermann Thorens 01 Ožu 2012 15:32 #883
  • MiljenkoC
  • MiljenkoC's Avatar
  • Postovi: 391
Sića :(
A jel to sa SME ručicom ili s njihovom TP?
Odg: Hermann Thorens 01 Ožu 2012 15:46 #885
The construction of the TD 160 HD is based on a progressively dampening sub-chassis owing to the newly developed compound suspension elements. This would also facilitate the use of uni-pivoted tonearms. The one-piece platter is made from acrylic material and driven by a belt at its underside, yet without the need of a sub-platter. The platter mat, a blend of cork, India rubber and polymers, has antistatic properties and ensures the optimal coupling of the record to the platter. The TD 160 HD features a base plate, tonearm platform and feet made from RDC, a very special compound of micro-granules, which provides outstanding resonance dampening throughout. The further developed electronic motor control prevents the synchronous motor from running hot, in particular when subject to extensive operation.
Odg: Hermann Thorens 01 Ožu 2012 15:48 #886
Odg: Hermann Thorens 01 Ožu 2012 17:08 #890
  • MiljenkoC
  • Postovi: 391
Pogledao već.
Dolazi s TP ručicom.
Još soma jureka za SME, WOW
Ne isplati se.
Interesantno da ima tri nožice kao moj:)
Istokario mi frend od aluminija.
Ono dolje je "clamp" 700 gr također hand made by my friend
Odg: Hermann Thorens 01 Ožu 2012 17:46 #891
SME ručka kad se jednom poštela onda nema potrebe za raznim akrobacija kao kod Linna. :evil:
Odg: Hermann Thorens 01 Ožu 2012 18:02 #892
  • MiljenkoC
  • Postovi: 391
Nije problem u Linn-u :)
Decca International je puno osjetljivija nego moja Formula.
Volio bih ga imati, samo maltus mi ga ne želi pokloniti :(
BTW maltus daj ga uslikaj da vidimo kak zgleda :P
Posljednja izmjena: 01 Ožu 2012 18:02 od MiljenkoC.
Odg: Hermann Thorens 01 Ožu 2012 20:53 #906
Odg: Hermann Thorens 02 Ožu 2012 06:04 #919
  • MiljenkoC
  • Postovi: 391
Nekaj ti je kapalo po tanjuru
Mast iz bureka?
Odg: Hermann Thorens 02 Ožu 2012 06:45 #922
Da dobro i duuugo vozis, moras i dobro podmazati B)
Nebum ti ga poklonil !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Odg: Hermann Thorens 02 Ožu 2012 07:36 #927
  • MiljenkoC
  • Postovi: 391
ŠKRTICA :angry:
Da znaš, sada ga i ne bih uzeo.
Zamastio bi mi sve plejke :cheer:
Tek tolko, da znaš :P
Stranica se generirala za: 0.242 s
